Rico's chopped II
RICO9
07/2014 OTOTM Winner
SL,UT
Title says 84.
I coulda sworn i had a build thread on here but i guess not so here you go.
This is as far back as my pictures go due to a computer crash.
Spring '05 a few months after chop.
as you can see the paint sucked but she was suprisingly rust free for an 84.
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
here are some more pics of how the cab was done.
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
shortly after this i ripped out the rest of the carpet, made the doors removeable and put on some primer.
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
mini photo shoot.
Rico's chopped II
Rico's chopped II
i finally rounded up enough cans of OD green paint.
Rico's chopped II
Rico's chopped II
found a push bar at the junk yard.
Rico's chopped II
then my 2.8 went KA-BOOM! so she sat for about 2.5 years.
2008 almost back on the road. she got a rebuilt 2.8 and tranny, 33's and round headlights, and 4.0 radiator.
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
ran her for about 6 months and decided to do a duraspark.
Rico's chopped II
Rico's chopped II
Rico's chopped II
also added a tach at the same time.
Rico's chopped II
one day i got a wild hair and decided to fix a dent that had been in my fender since before i got it. i didn't have any OD green left but my work has tons of flat black and flat brown so i thought, "what the hell". also took some forklift flex pics.
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
i also tinted my lights with this stuff and added some diamond plate to bed rails.
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
this is around the time when i snapped a d28 drive shaft and decided to upgrade to d35 and 8.8 so i bought a 93 explorer with a bad head gasket for $250. (made $200 scrapping it after i pulled the axles and seats and center console.)
here are the seats and console in with seat covers.
Rico's chopped II
you didn't think i was gonna just throw the new axles in there and be done with it did you? no sir. she gets 4.88's front and rear, an aussie up front with a set of warn hubs and a mini spool in back.
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
Rico's chopped II
front is ready to go back together.
Rico's chopped II
Rico's chopped II
if you do an aussie locker and don't do a c-clip eliminator you will need to grind on the clip to get it to fit in the locker.
Rico's chopped II
all painted up and ready to go in.
Rico's chopped II
Rico's chopped II
also scored 5 procomp 35" mt's.
Rico's chopped II
thats all for now because i'm sick of typing.
I have always been curious of how you sealed the bottom of the cab up, spray foam or something? Pictures?
I've seen this build before, just can't remember where. Looking good still.
Pretty nice man! I must say though, I like it at the two tone, just chopped phase. When you painted it green and black though, that's probably one of my favorite looks of a BII
there is a strip of rubber under that angle iron.
i have one on bii.org also. you finish your 4.0 swap yet? gonna be a beast!
thanks! when i get it how i want it i'm gonna redo the cammo a little better.
I got some more stuff over the last month or so that need to go on still. a set of Rancho extended radius arms, some 5.5" lift coils, a pair of longer Procomp shocks and some weld on universal shock mounts for the rear from 4wheelparts. i'd like some input on using the 5.5" coils with a 4" lift kit. will it work?
as of now all i need to do to drive it again is get some drive shafts made.
Yea, it should align fine with the 5.5 coils, but I would suggest using XJ coils for some flex
Alignment should be fine with some 3 degree bushings. What kind of 5.5" coils are they?
