- Oct 5, 2007
- Age
- 50
I have a 2WD 96 ranger daily driver with a 7.5 ring gear diff in need of rebuild. I am looking for a quality rebuild kit that will last and maybe give some added strength. I pretty much need everything spider gears, carrier, ring and pinion,axels and bearings. Not looking for a huge boost in performance just long term relaiblility and maybe some added strength for towing.
My fist issue:
The problem I find is that all the posi diffs and stock rebuild kits I find are 8.8. I dont know if they will fit in my diff housing.
Second:
Are there any stock type open carrier kits that "hardened" or beefed up in some way? Or would I be better off with a limited slip set like one from eaton?
Be gentel this is my first diff rebuild. I know little and am learning on the fly.
My fist issue:
Second:
