bobbywalter
TRS Technical Staff
TRS 25th Anniversary
Ugly Truck of Month
- Aug 9, 2007
- woodhaven mi
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
Not day one, but close to it.
It is tough to know which wheel is spinning on a tractor with big fenders if you can't see it... which I think would also be a problem on a pickup.
i dont have a problem detecting which wheel to lock.
the link i posted is old, i actually went to a remote setup with momentary switches right before i made that update which works great with the stock abs setups.
the gm setup i need to apply to my rig, just never got around to it. room is at a premium with the current engine, and time for refining stuff like that as my son takes up most of it...my daughters were allot easier on me
A BETTER WAY(update 6/10/06) {recommended for beginners}to wire it is to have two or so momentary buttons on your floor shifter, or fab a hand held controller and put the switches on it to suit your needs.
in this case of the 3 channel you only need two momentary buttons. you can put the ground for the rear brakes to each momentary, and the left brake to one switch and the right brake to one switch, this way when you turn the system on, all you have to do is hit the left or right switch and then modulate the brakes while throttling forward, when you let off the switch your brakes are back instantly. this should be the best way to operate the system. i will try to get pictures up before the end of the month.
it rides on the bucket back with ttb....
