mixwell
On the way to work today I noticed as I started to give my truck gas to speed up on the main street my truck started bogging down and lost a lot of power almost as if it were being choked. I just noticed yesterday that my temp gauge will go up close to hot and then drop drastically and then build back up again.
I researched some symptons and someone had mentioned in another post a faulty cat. I was speaking with a co-worker and he blurted out that it was my cat also because he had an identical problem. I'm assuming the exhaust heat isn't escaping and could be the drastic temp fluctuations ? I do know that I have an exhaust leak near the cat..
Any extra ideas would help, I have heard other symptons being fuel filter, misfire, plugs, plug wires, vaccuum lines but it doesn't really sound like it's a misfire, it does run smooth at idle but when you give it decent gas it's creating the issue.
Thanks in advance
Thanks in advance
