ok guys , after a slight hiatus that consisted of lots of school and partying and just alot of small issues with myself and just not knowing where i am going in life and not having good plans and just being overwhelmed and on the verge of losing it i am back and better than ever and i have a new build for y'all
now most of you that have been around for a while remember some of my previous builds and where they ended/what happened/where they are now
but for those new guys here is a slight re-cap
1. 2000 Ranger 3.0 to 4.0 conversion(Molly) - Completely shitcanned , using the engine for my 97 and the frame for the Level II
2. 1997 Ranger 4.0 4x4(Linsey) - Blew up the engine and am gonna replace it
3. 2003 Ranger FX4 Level II - Wrecked bad , getting its everything swapped to the 2000 Frame
4. 1996 Explorer - Nothing happening to it , well actually right now it is getting a new trans , but nothing else major
5. 1997 F-350 - Whole lotta stuff
Projects 1 , 2 and 3 , along with this project are not getting started till next fall , see hopefully i am getting a job at Yellowstone park this summer and when i finish up there , i am gonna come home and go on unemployment , do a bunch of training with the FD and work on the projects to keep me busy , then get my CDL before applying for a custom harvest crew job
ok so here are the stats on the next project i will be starting
Year: 1990
Model: Bronco II
Engine: 2.9
Trans: M5OD
Drive: 4x2
it is originally from Louisiana , pretty clean and i am gettin it for ~$800
here is the truck itself
and here is what i plan on putting in it
the plan it to just run the fullsize axles as they are (width wise) and just put Fullsize coil buckets on and space them out to get the spring angle right
the only thing i will have to do is figure out where to get springs and what size to get after i get the skyjacker 4 inch kit , and i am gonna sell some pieces off that since i am gonna make my own Extended RA's and my own RA crossmember
so here she be , it oughta be an interesting project
Year: 1990
Model: Bronco II
Engine: 2.9
Trans: M5OD
Drive: 4x2
