How to weld a diff on a 7.5 Plaese Help
reimic39
Hanover PA
I was wondering if any one Has ever welded a 7.5 diff Need help please
thank you
thank you
assuming its an open diff: open the cover, clean everything really well with brake parts cleaner, weld each spider gear to the carrier, and to each other. the end result will look like this
yup, just fill that sumbitch with steel. if you can't afford to stuff a new axle in when the welds break, you'll need to preheat and postheat the carrier and weld with a high-nickle rod.....yes, i'm saying you need to stick-weld it.
