- Aug 19, 2010
i just read up on my tweeter, turns out it has a built in 6db crossover
buy from a store, carefully unpackage, use it, then return it.
that is the remote turn on wire for your amps. its blue with a white stripe.
your amps should have pos. neg. amp turn on labeled on the side.
So it turns the amps on when I get power to the HU from the ignition?
The blue wire sends a signal to the amp when the radio is turned on. so the amp is only one when the stereo is on. its different then the wire that powers the stereo with the key on.
And since I'm in the process of asking these little questions, theres this little switch on my 2 channel amp that chooses either "low pass" or "full range". What exactly is the difference between the two?
full pass allows all the sound frequencys to pass through the amp on the speakers. low pass only allows bass, and is used for subwoofers.
the sub amp also, has this switch, as well as a bass boost switch and one that choses input sensitivity.
again, used for subwoofers. bass boost allows how much bass you want the subs to put out. and input sensitivity is something found on cheap amps. it really doesnt do a whole lot. its really a gimmick to make you think your "fine tuning" your amp. worry about the bass, gains, and frequency settings. those are the ones that determine the sound you want.
I have a 1990 ranger with the old cassette headunit pictured below. I'm going to be replacing with a pioneer HU. I need to know the proper way to remove it. What tools will I need? I also have a new harness that should work with the new HU. I'm going to be running it to two amps (A 2ch and a mono sub amp). Besides having to run the RCA plugs through a splitter, is there anything special I'll need to do as far as wiring (from the HU to the amps) goes?
Do not... i repeat... DO NOT try to rip it out without using the little holes like u need to. I tried this in my '89 and could not get it out. ended up wrecking my dash because by the time i looked it up it was too wrecked to do it haha.
