So how much did all of the air compressor stuff run you if you dont mind me asking? i'd like to put one in my b2 eventually.
one other ?, where'd you get your c-clip elim kit? i wanna put one in my 8.8 before i put everything back together
Tank was $80, compressor was $95 three years ago. If you want on board air be sure to get a constant duty compressor (I didn't and regret it). The constant duty ones are more expensive, $200 plus, but they are worth it.
My c-clip eliminator is for the front Dana 35 pig, the kits for the Ford 8.8 are very expensive, and most are out of production.
^hes probably referring to elimination of the e-clip that holds in the inner passenger side axle shaft...in which case use a spring for an echo lawn mower and weld on the shaft (its in the tech library)
correct me if Im wrong Legoms...
Correct, but I call it a C-clip, as I have no clue why people calls it an e-clip as it clearly looks like a "C" to me lol. Same thing though. Also you, don't have to weld it like the article says, just use hose clamps to retain the dust/grease boot on the slip joint and that will hold the spring in place so that it can't slip up over the larger part, rendering itself useless. This mod once done makes tear down of the front end much easier, as you don't have to remove the third member if you break a u-joint or axle shaft.
Another note, I sold the Yakima fairing, so my total expenditure was a total of $130 for crossbars, clips and q-towers. Not bad! I didn't like the way the fairing made my truck look and I can't mount bike trays to it anyway with it on so I sold it. Wind noise is negligible, its actually less noise than what the tires make.
