Really need help with this I have it posted in the 4.0 section also but I have to get this thing through OBD inspection before friday!
Vehicle: 1998 Ford Ranger V6 4.0L Vin X 2WD Automatic
Extras : Replaced Air Filter with a Cone style air filter, comparable to K&N Filter
Flowmaster exhaust system
Problem: CEL throwing codes Lean Bank 1, Lean Bank 2 (0171 and 0174)
Items replaced: PCV Valve and Hose
Fuel Filter
DFPE Hoses, they were collapseing
Upper Intake Gaskets, round rings on bottom of plastic intake
Gasket between Fuel Rail and Lower Intake
Oring around EGR tube into Intake
Additives used to clean fuel system: STP Gas Treatment, and High Test Gas. When I did this light stayed off 65 miles. After that tank ran Seafoam with High test light stayed off another 30 or so miles.
Results: Does drive better, better gas mileage, and resulting in better power. However this light continues to come on and results in a failing inspection.
Sidenote: It alternates to which code kicks on first, outta 5 times the bank 1 code kicks on first 2 times, the other 3 times it has been bank 2
Has anyone changed the EGR control Solenoid and that fixed lean codes? I could really use some help like I have been getting on here, I would hate to tear into this motor again to get to the lower intake when it may not be necessary.
Fuel Filter
