My idea of a Shelby Ranger if there would have been one.
multi youve done a good job, well done. Definitely worth being proud of.
Pull the codes, it will tell you why the CEL is on. Even if it isn't on at the current moment, the ECU will store the code and let you know. Autozone does it for free and it gives you a reason to go on a cruise!
Truck is lookin killer!
Thanks Kyle! I have a Snapon MT5000 scanner... I always thought the light had to be on for the code to be present...
Everyone at work loves the truck.. Got a lot of :icon_thumby: on the highway!
She has a few issues.
1. it idles rough as hell once it gets hot..
2. It dies some times.
3.the AC causes the voltage to drop like crazy (The battery is old as crap) could that be an issue?
I put a used IAC on it from my 2.3 but still died after it got hot..
haven't hooked it up on the scanner yet...
I can't believe how bad it idles.. It is very rough!
Cleaned original IAC but haven't put it on yet...
sounds like a spark issue..except for it not happening when cold
might just be the computer getting its settings
yes, definitely. that sounds like your alternator isn't putting out enough power when power is routed to your a/c system..which says to me you have a short in the a/c wiring somewhere (possibly)
I STILL can't believe how slick that black looks:cool:
I forgot I took a few pics with the BlackBerry at the alignment shop...
wow is your tailgate a freaking mirror!!!
that does look sweet man! good job!
EDIT: Having the blower running sucks down the voltage gauge not just the AC...
