I agree, in an off road rig the V8 swap is more work that it is worth. Now a street truck...different story.
Ok, got my rear axle partially mounted, then started wondering if I want it there or if I wanted to move it forward more.
So, I leveled the frame out at ride height, set up the front axle under the truck in position, about 1.5" to 2" forward of stock, measured my wheel base at 114" to 115", not too bad, about 10" shorter than it was. Then I got wondering where my rear cab mount was going to end up so i measured that out and it ended up being dead in the center of the front spring hanger. see pic
my cab mount needs to be at about the 5" mark, but i think I can move it easily to the 4" mark.
Now the problem, I don't think I can fit a standard cab bushing/bolt in that space.
Question, should I say F it and try and make it work or move my axle forward the necessary distance and make it a shorter wheel base?
Please, give me your opinions!
