Fan Clutch Std or HD?
A diesel rated over 18k has so much in common with a Ranger...
For short bursts are a long time at low speed a e-fan would be superior. Like a tractor/truck puller that could gain the extra power for the 300' down the track and then flip it back on. Long periods at really slow speeds, a lot of idling, or water crossings would also give the e-fan an advantage.
'09+ F-150's come from the factory with them, which kind of makes whatever point you are trying to make with your aftermarket fan thing null.
They came on my last car from the factory, and you could sure tell when they were running, they sucked a lot of power. Aside from it just staying cool I can't tell what the mechanical ones are doing.
And most 4.6's were made at the Romeo plant in the US. :D Windsor 4.6's are kind of uncommon freaks... at least here in the states.
Dude!
My new HD trucks are all 3/4 ton with gasoline engines. They all have clutch fans in them. I'm guessing because the clutch fans can be depended on to keep the temp down to the desired temperature regardless of what the truck is towing or not.
Then again all my newer 1/2 ton trucks that must meet fuel milage regulations all have Efans on them.
Yeah they both work for their intended uses. But to take out a perfectly good system and install another that doesn't do BETTER is a silly thing to do...in my opinion.
The ONLY reason I can see in my mind's eye to swap out a clutch fan and install a Efan would be if the driver intended to drive off into deep water and also needed other precautions for deep water.
Big JIm:hottubfun::wub:
I was debating this statement:
If you have a truck that does heavy towing, then you get a heavy duty e-fan where you can set it up to accommodate what you r using it for.
Bottom line, an e-fan doesn't have the capacity of a mechanical fan/clutch assembly.
Well I still prefer and reccomend an e-fan if its for any offroading definately for its numerous advantages, even if you r a weekend warrior
wow all of this over fans. ok the e ones are great for off road uses cause of what has been stated before can be over ridden and turns off and on when it needs to and or when you tell it to. you know what lets start at the very begining.
The cooling system consists of 5 basic parts: the engine, the water pump, the radiator, fan and the thermostat. Water passages inside the engine are filled with an ethylene glycol/water mixture (commonly just called "coolant"). These passages allow the heat that is generated within the engine to transfer into the coolant. Coolant is circulated through the engine via a water pump, which is driven from a belt off of the main eccentric shaft pulley. The stock fan and fan clutch assembly also mounts off the shaft of the water pump, and is therefore driven by the engine as well. The pump's job is to circulate water though the engine and the radiator. Air flowing over the radiator cools the coolant, and thus the engine. A thermostat is used to open or close flow of coolant through the rad to maintain the engine temperature at a constant (approximately 180 F). It is very important to realize that it is the thermostat that regulates the temperature of the engine, and not the fan. You can install the largest fan possibly and move as much air through the radiator as you want yet the temperature of the engine will remain the same as set by the thermostat.
Now that we know how the cooling system works, let's be clear about the function of the fan, and how the clutch assembly works. As mentioned, the stock clutch fan is attached to the water pump shaft. This shaft receives it's rotation from the engine itself. The fan is not directly attached to the shaft, it is actually bolted to a viscous clutch. The clutch then sits between the fan and the shaft. The purpose of the clutch is to keep the fan at a (fairly) constant speed, and to only engage the fan when it is needed. Think of the clutch as a very simple mini torque converter. Inside is an impeller that is connected directly to the input shaft. This impeller rides on a bearing so that it can rotate independently of the clutch housing. The housing has a disc that sits opposed to the impeller. This disc is controlled by a bimetal thermostat so that as the air flowing over the clutch heats up, the thermostat moves the disc closer to the impeller. Filling the entire housing is a thick silicon fluid (or sometimes a heavy gear oil). As the disc moves closer to the impeller, they become coupled by the swirling of this fluid. Because the disc is splined to the housing, the housing begins to rotate and thus the fan (which is bolted to the front of the housing) spins as well.
As cooling air flows over the clutch the thermostat relaxes and moves the disc away from the impeller. This breaks the coupling and allows the clutch to slip and finally freewheel. Similarly when you stab the throttle or when the engine is operating at high RPM there is not enough force coupling the impeller to the disc and the clutch slips to keep the fan operating at a constant speed and to avoid robbing power from the engine.
The (very crude) image below illustrates the assembly. A more detailed disassembly of a fan clutch can be found at Jaguar V12 Fan Clutch
I guess the pic isn't gonna work sorry.
What's important to note is that the fan is only used when the engine is idling, or the car is creeping along at low speed (less then 20 MPH). If the car is stationary or creeping, there is not enough natural airflow through the rad to provide adequate cooling. Thus, the necessity of a fan.
Now that we know the basic operation of the cooling system and fan, let's look at the electric fan.
By far, the most common misconception is that the electric fan cools better then the stock. People see the high CFM numbers in the catalogues (for example, the Black Magic is advertised as pulling 2,800 CFM, and the Perma Cool "finger chopper" is advertised at 2,950 CFM) and are impressed. The truth is that no one actually knows the CFM rating of the stock fan. It has simply never been measured by anyone but Mazda. Some estimations have been made that it is approximately 2900 CFM at 2600 RPM using software modeling. But as these are estimates we can never know for certain how ford has rated this fan. All we do know is that it is rated at "enough". And to be honest, who cares how much air the stock fan moves? It is more then adequate as long as it's clutch and the rest of the cooling system is in good shape. The steeply raked blades of the stock fan move quite a lot of air, even if it turns slower then an aftermarket electric unit. It's also a bit irrelevant how much capacity the stock fan has as compared to aftermarket fans on a modified car because the fan is only used during idle and light-load situations. The fan to cool a 400HP engine is the same size fan as would be used to cool a 200HP engine since both engines are producing the same amount of heat during idle and light cruising.
Many people also seem to believe that an electric fan will cure their "at speed" overheating problems. Recall that the fan is not even used when at speed, as the natural flow of the of air through the radiator is more then enough (much more then a fan, in fact) to keep the car cool.
Of course, you're not necessarily after better cooling. You've seen those TV commercials or catalogue ads that promise "Up to 17 free HP!" by converting to an electric fan. Well, that's simply not true. There will be a horsepower gain for sure, on the order of 0.5 - 1HP. But remember that the electric power to run the fan must come from somewhere, and that somewhere is the alternator. Electric fans draw quite a lot of current. Most pull surges of 35A or more to start up, then run at 8A-10A. This puts extra load on the alternator. Ever pedaled a bicycle with a generator powered light? If so, then you will know that as the electrical load on a generator/alternator increases, the generator/alternator becomes harder to turn. Suddenly, all that "free" HP you just freed up is once again being used. This time, though, it is being used to turn the alternator. There is also an inefficiency in the whole system. We are converting mechanical energy, to electrical energy, to mechanical again to run the fan. This very inefficient, much less then just driving the fan directly via the mechanical energy of the rotating shaft.
Let's examine the "17 HP!" claim a little further to drive the point home. A little basic math is all that's needed.
One horsepower is 745.69 watts.
Therefore, 17HP = 12,676.89W.
Since W = Voltage * Current, 12,676.89W is 1056 Amps
So in order to do the same work as that stock "17HP" fan, an electric fan would have to continuously draw over 1000 A from the electrical system of the car. Clearly this does not happen. Now I'm sure that somewhere out there is a car or truck with a ridiculously inefficient and so poorly designed stock fan that it actually does rob 17HP from the engine as it turns. But not in this case.
now to figure out an electric fan and factor in the inefficiency of the alternator and the fan motor. Assuming it takes 1HP to turn the electric fan:
745W = 62A at 12V. This is obviously already incorrect since it's ridiculous to assume that an electric fan is drawing 62A continuously. But we'll continue anyway.
Assuming that the alternator and fan motor are both 70% efficient (an over estimate for sure considering the quality of automotive electrical parts...see Alternators) we need to take those losses into account.
So 62A + 30% = 62 + 18.6 = 80.6A
Then add another 30% for the inefficiency of the fan motor: 80.6A + 18.6A = 99.2A
If our e-fan really saved 1HP from the shaft of the engine, it would be drawing almost 100A from the electrical system of the car to do the same work! We can see that this is not the case.
While on the subject of the electrical system, let's look at how the fan is actually connected. The proper way to control an electric fan is via a thermostat and relay combination (fused, of course). Unfortunately, very few people actually do this. Many installations simply connect the fan to run all the time, or to a switch inside the car. In the latter case, your brain actually becomes the thermostat. Needless to say, this is a very poor arrangement as it is easy forget to switch on the fan as the temperature climbs. Worse still, the 1989+ temperature gauge is horribly inaccurate. By the time you see it move, the car is already too hot. Leaving the fan on all the time presents a different set of problems. It becomes an unnecessary drain on the system, and is totally unnecessary at speed. Thus all that "advantage" the electric fan has over the stock fan disappears. This is not necessarily a flaw of the fan itself, but of the installer.
Lastly, there is the question of reliability. The stock clutch fan can have two failure modes: the clutch will fail, or the fan will physically break. The electric fan introduces many more failure points: fuse, all wiring connections, physical failure of the fan, failure of the motor, failure of the thermostat.
By now, you're probably wondering "Gee, why is this guy so against electric fans?". Well, I'm not really. But I recognize their disadvantages. There are also some useful advantages to the electric fan.
The subject of fan efficiency has been ignored until now as it can work both ways. The majority of a fans efficiency is dictated by the shape of the final few inches of the blade and whether it is ducted or not. Here, electric fans can have a significant advantage. It is hard to say what the efficiency of a fan blade is without aerodynamic testing. A stock fan may have very efficient blades while an electric fan has poor blades, or the stock blades might be horrible compared to the electric fan you are looking at. But a big gain in efficiency with an e-fan is in the fact that the blades are more easily ducted. Because the electric fan drive motor is mounted directly to the same frame which mounts the shroud, clearances between the fan and shroud can be much smaller then that of an engine mounted fan. The smaller the clearance between the tip of the fan blade and the shroud, the more efficiently the fan will move air. Some fans go a step further and have a ring around the outer circumference of the fan on the blade tips which rotates very closely to the shroud. This is a very efficient design.
Since you are no longer tied to the shaft of the water pump, the electric fan can be oriented in any way, and moved around to make space. Without the stock fan shroud in the way, there is much more room in the engine bay, as well as room to route things like intercooler piping, cold air intakes, etc. An electric fan may also be required when going to certain aftermarket radiators that do not have provision for mounting the stock fan shroud.
The electric fan can also be left on after the engine is shut off. This allows continuous cooling to minimize heat soak. A small turbo timer like device can be used to run the fan for a preset amount of time.
Perhaps the greatest advantage of the electric fan is cost. It provides an affordable alternative to replacing a failed stock clutch fan. The stock unit is very expensive when purchased new, so it is possible to save several hundred dollars by purchasing an electric fan instead. However, this advantage is not as great if you have a decent wrecking yard in your area. Used clutch fans are very cheap.
There you have it. For the most part, electric fans are not recommended as an upgrade unless you have a very specific reason to do so. They may provide inferior cooling to the stock fan, and may create other problems if improperly installed.
so all i need and had worked great for me is stock fan and clutch :buttkick: :haha: so yeah now you should be doing a little something like this. :pray:
Someone... PLEASE... lock this thread. It's obvious that we can't get along talking about engine cooling fans.
I'm really disappointed in this thread. Not ONE of you actually answered the OP's question. All he did was ask what the difference was between a standard clutch and a heavy-duty clutch, and you guys can do nothing but bitch about whether an electric fan is superior to a mechanical one. I didn't see the word "electric" anywhere in the first post.
Well I AM going to answer the OP's question the best I can, even though the OP probably went to some other forum to find his answer over a year ago. As far as I know, the heavy-duty clutches are used on auto trans trucks, and the standard clutches are on manual trans trucks. That's what the computer at work seemed to imply when I looked up a clutch for my truck. I went with the heavy-duty one.
Doncha think
You were a little late! That question was asked 18 months ago! I highly doubt the guy has been sitting around waiting for your post.
Umm, yeah I know. I already SAID that. If I had simply said "No one answered the OP's question," someone else would have said, "Well, neither did you." At least if someone else in the future was searching for this topic, he can at least get some somewhat useful info, if he can stand to read through the first 4 pages of bickering bullshit.
Hi all. I just wanted to say that I'm glad this thread wasn't locked.
I know there seemed to be some arguing, but it gives perspective on the subject, and allows anyone following along to see a variety of opinions, the reader can use his or her own head to judge the credibility of the posts.
I read with interest all of them, esp. the post above by xentris.
Btw, I found this thread on a search, as I am having cooling issues with my '90 Ranger that I believe are fan related.
I'm a recent member and have posted very little thus far as I am not a particularly good wrench and have far more to gain by reading the posts of others than by any information I may have to offer.
I may make a follow-up post after I have resolved my cooling issue.
Thanks to all who participated - Dan
i feel like beating a dead horse. E fans are the shit lol. yeah im pretty sure my clutch/fan does just fine its a little noisy but i'm planning on an e fan in the future, with a clutch style fan they cause way more crank drag even with the clutch disengaged there is all that extra belt wich means more drag and work for the crank, also with an efan if it stops working cause of a loose connection you can troubleshoot that if your stuck somewhere you cant trouble shoot a grenaded clutch. its just old technology and also to you guys who are talking about towing and how theyre bad your driving a ranger bro not a superduty its a light duty truck a "parts runner" if you will not a diesel tow rig
I think this is the second time I've read this thread. It was answered in #28&69 :icon_twisted:. I wonder if someone searched electric fan if this would come up?:dunno: Personally I would just get the HD. Makes me think of when I put a flex-a-lite fan on my car, don't know or care if it made a difference but it looked cool. Course it was so long ago that fan clutches weren't invented yet:icon_rofl:, circa 1972:icon_rofl:. Your results may and will vary, and "frankly my dear I don't give a d@mn".:icon_rofl: Quick, what movie was that line from?
