- Aug 8, 2007
- Age
- 37
- Battle Ground WA
Cummins 4BT
I would rather have a V-8, the stuff they have to do these modern diesels to get past emissions is rather scary and makes them very difficult to modifiy.
A 2.3T would be fun to have too.
Do you have a video of this? I would love to see that big ass truck haulin down the drag strip
And I'd like to see and I6 gas twin turbo engine laying down nearly 700HP and 1500FT/LBS and still pull 20MPG in a fullsize truck. Ain't happening.All you guys jumping on the diesel bandwagon is funny. People are so in love with diesels thinking the performance is so much better than a gasoline engine simply because it runs on diesel.
The reason the performance is better on modern diesels is because they have direct injection and run huge amounts of turbo boost.
Take a 6.x Liter Gasoline V8, add gasoline direct injection, and then throw a turbo or two on and crank up the boost (to make it "even" with the current diesel engines). Then see what happens. If any of the big three did this (Ford is currently working on a 2.0L I4 and 3.5L V6 with said technology) everyone would quickly forget about diesels being "performance" engines. The two wouldn't even be comparable, the gasoline engine would walk all over the diesel engine in every area of performance.
Hahnsb2 said:And I'd like to see and I6 gas twin turbo engine laying down nearly 700HP and 1500FT/LBS and still pull 20MPG in a fullsize truck. Ain't happening.
Sevensecondsuv, for me its not all about the performance aspect, its also about the reliability aspect. Sure those 6.something gassers will be making decent numbers but how long are they gonna last. Diesels continually spank gassers in the mileage and longevity fields. And if you want a truck to go fast, sure a high spinning gas engine may be the answer. But if you want a truck that would be a work truck a diesel has much more available torque at a lower rpm and will be reliable.
you dont read diesel power then do you??? this is the exact same thing that things were said when fuel injection came out......theres lots of things that can be done
gimme the diesel any day!!!!
Sorry, even with direct injection I cant see a gasoline engine taking 50-80PSI of boost like a diesel will, not to mention a diesel is capable of running at VERY wide variety of air/fuel ratios unlike a gasoline engine.With direct injection and as much boost as the diesel is running yes it would. It would probably make more.
Again this is not the case. The forthcoming gasoline DI turbo engines are by design and the fact that they are turbocharged, not only "high spinning motors"! They will produce huge amounts of torque across a powerband twice as wide as a diesel. Also, how can you say anything about longetivity of an engine that isn't even in production yet? It could very well end up being even stouter than any diesel engine produced today.
Again, you can't compare a turbocharged direct-injection diesel engine to a naturally aspirated port-injection gasoline engine. Not in terms of HP, Torque, Fuel Economy, etc. etc. etc. That's comparing apples to oranges, even though those two are what's offered in todays pickups. Save your comparisons for 5-10 years, when turbocharged DI gasoline engines are being offered alongside the equivalent diesel engine. You'll probably change your mind.
Now diesels have their place, but that's in tractors and semi's. I can even see the point in a full size heavy duty pickup thats going to live life with 20,000 lbs behind it. But they're not the answer for the Ranger-sized and half-ton trucks. I want to see Ford spend the R&D money on DI turbo Gasoline engines. Apparently they are. Look up the "Explorer America" concept. It has a 2.0L DI turbo gasser making 280 HP / 300 Torque across a wide power band and still getting 25-30 MPG in a 4500 lb brick of an explorer.
