Can a V6 actually sound GOOD.
the intake is nearly louder than the exhaust.
2.9 w/ 58mm TB, CAI, 12* timing, catback - catco 2.5" hi-flow, 2.5" flowmaster 40 delta flow.
that sounds deadly almost like a tubro haha. whered you get the 58mm to?
Oh and the forced induction sound is from the intake, like I said.. its as loud if not louder than the exhaust.
i love my straight pipe side exit 2.9 with cats. simple and sounds pretty mean. i dont want my damn ranger to sound like a v8 unless i put the work into swapping one in.
sure can. i enjoy the low rumble of a 4 liter everyday. 2.5" after the cat to a thrush welded and dumped before the rear tire.
my brother put a 5" exhaust tip on it. everything else on the exhaust is stock. It sounds sweet and definately has the low rumble you want
exactly, my brother got true duals with two 3" boom tubes stickin out the arse on his 87 stang, but its a modded 5.0 lol not a ranger with a v6
No a v6 can never sound good... :rolleyes::rolleyes:
Have any of you ever heard a Nissan GTR? That's a... "gasp" V6!!!
V8 is not by any stretch of the imagination the only good engine sound. Almost any motor that is a healthy high performance motor sounds good. Bullet bikes, Cummins Diesels, Audi W8, WRX flat 4, VW VR6 and R32, Honda S2000.... Need I go on?
My 2.3T might sound like a tractor at idle, but you get up to WOT and it's got a very nice exhaust note. Different than a V8, yes. Good sound, yes again.
nope. No diesel swap. still the normal v6. and they aren't boom tubes. It's a custom tip. He made it in his metal shop class and put it on himself (He went to a metal tech/welding school so he knew what he was doing). it probably only about 8 or 9 inches long. But i can tell you it sounds and looks sweet
Using a glasspack you might be able too.
you know, theres a reason this forum is called TheRANGERstation, and not theFOREIGNstation:thefinger:
