Springs?????
DeanCampbell
are explorer springs bigger than my 95 ranger springs??? if soo what year would work the best for fittin a 33's on with a 3'' body lift
f150 springs cut to desired height
or spacers??? how do i make them??
A bunch of large washers welded together and some longer bolts.
yeah they are bigger and they fit fine.
I've been meaning to make a set of spacers for my 97...I could probably be persuaded to make another set for yours....
r1hatman put f-150 springs on his truck and got i believe 3in of lift from it. it will also make the ride a bit stiffer. search for his threads and that will give you all the info you need for f-150 coils or you could ask him
I thought hatman had to use the f150 buckets as well? Bobby are you sure they drop right in?
Out of what? I do have a rather "slanty" 93 now...
:D
Probably about 2" (1.5" spacers) to level the truck out.
Might start on them in a little bit actually....just have to see what I have for scrap steel kicking around.
Sorry for the thread jack, but can you put bigger springs or cs spacers in a 98-00 with coil spring front suspension. Ive never found cs spacers for my year ranger, just wonderin if there was a cheap way i could get about 2 inches of lift in the front of my ranger.
Cool let me know when you do. That's pretty much exactly what my 93 needs. It'll give me some inspiration:D
