Fabricating anything right now?
since yesterday my 79 bronco runs perfect, so probably by the weekend if shes still going good ill be making a winch mount for a superwinch8500
yes It goes in my reciver. I dont have floor space to dedicate to a perminant mount tube bender so the stand slides into my reciver and a jd2 model 3 bender mounts to it, the bender is mounted on 45 to the truck so I can bend any length tube to 90 degrees without hitting the truck, i'll post another pic when I get everything assembled
you get anything done with that peice since i last seen it?
i just made a skid plate for my front bumper ill post up some pics later
here's a few jobs i'm building @ work
just got this one back from Powder coat and finished install...
here are some rose gates I built for my boss...
powder looks good except for the yellow roses not sure why he wanted some yellow?:icon_confused:
flat bed for my old diesel...
here are just some random jobs i've done over the last two years, and some that are currently in progress...
roof rack
lots of pics eh!
-Jason
im working on learning to weld lol
but yea i somewhat improved since then, i slowed it down a lil and cranked her up a little bit
Try welding in little circles and if you have a good helmet you can see the puddle form
What kind of rod and machine do you use? I'll bet with cleaning the rust and mill scale off that plate first you'd see a difference, if you haven't tried that already.
-Jason
Bogger slow down and turn the heat up. Yeah what rod are ya using too? You should have the rod at about a 0 to 10 degree back angle and feed it into the puddle. Once you see it form just start making little C's all the way forward or the circles. Some guys also push it forward than pause than push forward and pause. send us some new pics man
good luck
yea i kinda improved some since then ill try to get some pics of the new stuff tonight. im not sure what the rod is.. maybe 1780?
I still have a bit of work to finish it but it will be a adjustible press with a few differend heads for different work.
[/IMG]
[/IMG]
[/IMG]
Im not trying to brag about my welds, they are not as good as they could be but these were done with a 120V Lincoln SP125 that was given to me free cause "it didnt work" I put a new liner in it and have been using it for 2 years with 030 flux core wire
[/IMG]
thats some real good work bud
