- Dec 6, 2009
- maplevalley WA
It is either the thin wall socket or a torx head screw holding it on. You can pull the codes too and see what it says but until you get it to warm up to normal temp do the KOEO test first and address each in order lower numbers first and disconnect the battery for 15 mins every one to see if goes away. when you start it have the timing light on to see if you are losing the spark when it dies. I believe you still use EEC-IV the tech library shows you how to pull the codes and what they are for.
