reliability?
Rusty_Ranger
is the old 2.8 a reliable engine for a daily driver??? and is there any tricks to keeping it reliable other then proper matinance?
IMHO if the engine is in good shape, and you properly maintain it and make necessary adjustments then yes. On-the-other-hand you have to keep in mind that the newest 2.8 is over 20 years old now, and that they are based on a design that's almost 35 years old.
Mine is daily driven and has 272,xxx on the original engine. All I do is change the oil and airfilter and add a can of engine restorer to it at every oil change.
Its reliablity resembles that of a hammer. Just keep oil in it and don't get it hot and it will last you a long time. That is of course if you lose all the computer controlled junk on it and run a non feedback carb and duraspark it.
i have a 2.8 that is still going after 25 yrs and 3 owners.
Very reliable engine.
No special tricks to keep it going.
I would however replace the FIBER camshaft timing gear....
Mine just literally blew apart on my way home from work a few years ago, replaced it with aftermarket aluminum gear.
That is the only mechanical problem I've had with the 2.8, most of my problems with the 2.8 is the ignition/electical system, but that needs upgraded to the Duraspark conversion and the replacement of that rear solenoid regulator on the carb with a custom valve,you shouldbe good to go!
and that mysterious "10 tooth starter gear" mod, but I am nit-picking. :P
"10 tooth starter gear" what's up with that? Did you break a few off.
what do i need to do to get rid off all the "computer controled junk and convert to dura spark". the truck is a 83 if that helps
Upcoming TRS Events
Featured Ranger Based Vehicle
