- Jun 19, 2009
- Hartsville
- State - Country
- SC - USA
- Other
- Mustang
thanks. now, i need to bleed the clutch line. arghhhhh
that isn't all that bad
that isn't all that bad![]()
two places to look: over by the harness bulkhead going to the engine should be a plug that has green and red wires on it. the green wires should go to the clutch pedal switch and be shorted in start. that should be a black plug that should have been left alone. there is also 2 wires in the trans pigtail, i believe black/white on one end and the one next to it (pink, purple or tan) that needs shorting OOPS thats reverse lights
red/black and white/red are park neutral and they are opposite the locating pin.
There is a 5 pin plug that plugged into the auto trans. One pin was for converter lockup, two for reverse lights, and two for neutral sensing. If the two for neutral sensing are not wired into the Mazda trans neutral switch (on the passenger side of trans) the engine won't start.
