- Aug 6, 2007
- Age
- 79
- St Bruno, Quebec
1991
The rust around here is like an alien life form, it eats everything and nothing seems to stop it.
Por 15 it.. it will stop rust in its tracks and you will never have to worry about it again! enough said.
it actually adheres best to rust, the instructions tell you to get the loose rust off and clean the surface to be sure its clear of dirt and grease and you can brush, roll or spray it on. i brushed mine on my frame. one quart should do an entire frame.How exactly does this stuff work? would i wire brush as much of the rust i can then apply it?.
any automotive paint supply store will have it. ive also seen it on ebay and other online stores. it costs about $40 a quart. just a word of warning, DO NOT get it on your hands, it really does take weeks to get off your skin. once the stuff cures onto the frame if its prepped right nothing short of a grinder or chisel will get it off, its tough stuff.Where is Por 15 sold and what's the best way to apply it??
@01_ranger_4x4, did you cut out your rockers?
thats gotta be good for the enviroment. i kno hydraulic fluid(atleast military grade) will not come off anything.
http://www.por15.com/
heres a little before and after from when i did my frame and suspension
