ForOffRoadDriving
thanks ranger svt, that cleared things up a little bit. so far i think ive got a plan of execution for this thing, as long as i can get that kenwood pictured above fixed. im going to run 1 sub off from each of the small amps (the MTX RT202s (200w)) and then ill combine my front speakers on one channel and my rears on the other and these will be running off from the MTX RTP 202 (400w). or i could do it the other way around, use the 400w for the subs and then use the 200w to run the speakers, that way the out puts on the stereo will plug directly into the amps without messing with rca Y cables. i want to get this wired up on my next 4 day weekend, since im going to gut the entire interior to run all the wiring cleanly in 1 shot(nothing will be visible on the exterior). any suggestions on getting that kenwood fixed, maybe i should feed it 12v and bench test it so see what it does so i can describe the problem better?
