Just Plain Stupied
yep...dicy......that's what it does to the '36 FRONT & REAR when I have the shocks connected in pairs.....but not any more.....Waaaaaaaaaaaaaahahahahhahaaaaaaaa
i gotta get back out there & finish up......
EDIT: tonite........test drove '36 an hour ago with air shocks independent of each other....rides even better now over all kinds of bumps......no wheel-hop at all....I'm running 50 psi in each shock ( was running 30 psi per pair)........truck is even smoother than before.....Waaaaa!
But.......the torque converter still isn't locking once the truck goes into 4th gear & I ease up on the gas pedal.....no problem....as soon as the V.A. dru.......meds wear off a little, I'll find the problem (i probably hooked up a pressure switch backwards)
Waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahaaaaaaaaaaaaaaaaaaaaaaaaaaahahahahahhahhahaa.....cough.followed by sinus headache.....Waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahahahahahahahhahahaa............HYENNA!........
Thanks M M......i needed that.........that's just the kind of stunt Blake would pull on me!
Maybe a trip to the French Quarter for benei...bieen.........been--yays(never could speell that werd) and hot coffee is in order......
yes im hear!!
Congrats DG Blake would be proud.
and good thing you got teh socks fixed hot coffee and bouncing about like a low rider dont mix.
yes im hear!!
especially since he doesnt have cup holders:icon_twisted:
if he spills the coffee tho, he could sue them and make them put cup holders in for him:stirthepot:
Do you think the settlement would be enough to put the robotic rising/lowering heated cup holders in?
Hyennas !!!!!!!!
I spent a couple hours under the truck changing weights & springs....now it shifts into 4th at 45mph under light accelleration (instead of the usual 65 mph!)......
However, it will still spin em when it hits 2nd gear under medium accelleration....I think I'll just leave it that way.....Waaaaaaaaaaahahahahaa
I re-re-re-wired the xmsn again...it's officially getting 12 volts to the lock-out pressure switch, but a-parrottly I have the unlock vacuum switch connected to the wrong source on the carb.....there's still no lock-out at 60mph......
no problem.....the drugs will wear off soon enuff....
Hyennas !!!!!!!!
u still messing with that tranny??
thats what u get for using GM stuff...:icon_rofl:
keep it up DG, i bet those air jordan shocks are a cool add on :icon_thumby:
No! It's messin with me! Waaaaaaahahahhahaahhaaaaa
True....true.....
You got that right.....like I sayed...I should have done them 20 years ago.......
gotta go......bye!
Glad I could help:icon_thumby:
Your truck is definetly my favourite 2WD on TRS, maybe even my favourite truck completely now that I think about it.:D
theres others??:icon_confused:
DGs is most Defentatly my fave ranger.
i would say fave truck but mines on here and i fear it hearing that and bursting in to flames when i start it just to spite me.:dunno:
thanks men!!!
I put 200 more miles on the '36 this weekend.....still no over-drive (torque convertor lock-up) ..........but that's just part of the f-u-u-u-u-u-u-n !!!!!!
Good new is.........it'll pass anything @ anytime in a hurry!!!!!!!
No pics....the weather was too nasty
Its more like what year Caddy (36-89) does it handle like?
