whats a good gear ratio for the d44/9" on 35" tires. i plan on driving often on roads. i was thinking 4.56. anyone have any advice?
I just cut the whole block off, then built a mount on the axle tube to house a heim joint.
do heims work well for trac bar? i have heard they wear fast. also would that be good for driving on street?
Cut, sleeve, flex joint, done.
http://www.therangerstation.com/forums/showthread.php?t=12686&highlight=daily+doubler&page=21
If you're worried about bending, you can run a strip of angle down the length of the arm. Or I've even seen guys weld a strip of steel on edge on the top of the arm.
