- Oct 13, 2009
- Winnipeg, Manitoba
So I had a bit of an incident yesterday while driving home.
I work just outside of Winnipeg, Manitoba, in a town called Oak Bluff, while I live inside the city. So, when I drive home, to make things interesting, I take the farmers' roads. Right now they're snow covered, and in some areas there are some pretty major drifts. In fact, during my Xmas break, I got stuck in one of the larger drifts, and had to get towed out. I now avoid that road.
While I'm driving home, I see a vehicle stuck in one of the larger drifts on the road that I avoid. I decide to approach and see if he needs help. As I'm driving closer, I'm plowing through some short snow drifts, that as long as you have momentum, you can get through. As I get closer, I see a 2001-ish F150 crew cab with three dudes frantically shovelling and pushing, with snow flying from spinning wheels.
So, I pull up and mention that I have a tow strap. We hook my strap to each of our tow hooks. (the front of my truck was facing the front of the other truck, so that I was pulling backwards). It took many tries, but I eventually got him free, bit by bit. I couldn't just pull him out, because my truck is too light. I couldn't just sit there and spin, because I would have dug myself in and then we'd BOTH have been stuck. So I had to yank him out. A few times, my tow strap (which has really crappy hooks) came loose, and we had to re-attach it.
So, finally the F-150 is out. The dudes are showering their thanks. I put my stuff away, and get back in my truck. I didn't want to risk turning around and getting stuck on the verges of the road, so I start reversing back the way I came. I make it to one of the larger snow drifts, and pick up a bit of speed. Unfortunately, my truck slides out of the existing ruts and starts ploughing through the deeper part of the drift. A lot of gas and wheel spin just gets me through. Then I see the guy in the F-150 follow through the ruts I just made --------- and get stuck.
So I drive back to his truck, we hook up tow hooks again, and I start yanking (that sounds bad). Now...here it comes....
During one of the tugs, the hook that's attached to the other truck comes loose, and starts flying towards my truck. It flies through my grille, and punches a hole through my radiator.
I finish the job of pulling this guy loose, then I stop my truck and have a look at the damage. The hook damaged (cracked) the grille a little. And it seems to have bent a row of tubes in the rad back about 1.5", as well as flattening a lot of fins The thing is, my Rad doesn't seem to be leaking coolant. There's no steam, my coolant level in the reservoir seems to have remained the same throughout the night and my truck's temperature seems to hover about where it should.
I plan on replacing my radiator come spring, even if it IS okay. My truck is an '06 and I want to keep it nice, you know. But I want to wait until summer, because it's just too damn cold to do any work on my truck during winter. In the mean time, it's my daily driver. So, I'm planning on getting a bottle of rad sealant, and keeping some coolant in my cab. You know, just in case.
I'm just amazed at the quality of Ford products these days ( I had a long string of imports before I bought my Ranger). I mean there is some pretty visible damage to the rad, and it seems to be okay.
What do you guys think? Is there some other symptom that my rad is actually punctured that I should look for?
