Will these fit???
⭐Supporting Member
Ok, so I'm sure this is a question that has ultimately been asked about every other thread, but I'm just not finding a yes or no answer to it, so I'm asking again.
I found a set of rims that I love, they are the size I want, they look great. I can't find them in the backspacing I want.
I have a 1st gen 4x4. I plan to put a 4 or 6 inch (haven't decided yet) suspension lift on it. Will I be able to run 16x8 with a -19 offset and 4.5 backspace without rub issues, or are these going to cause problems. I'm planning on running 33x12.50s on them.
Here is the link to the rims:
http://www.4wheelparts.com/Wheels/A...0&t_pt=101002&t_pl=101316&t_pn=W/PAX398589582
Those are good looking rims. Do they come in a bolt pattern other than 8 on 6.5? That could be a bigger problem than backspacing
Yeah I could only find them in a 15x8 with the bolt pattern he is looking for. But they had the right back spacing and stuff.
you can buy them direct from AR in a 5x4.5 bolt pattern in 16x8.
Well in that case you are probably going to want to go with the 6" lift just because its a tight squeeze with a 4"lift.
Yeah. I was looking through the pictures of the lifts on the Tire Fitment page in the Tech Library. I like the look of that green one with the 6 inch and the 33s. I think that's what I'm gonna do.
But ARs web site, if you look up by vehicle it only lists them in the 5x4.5 at 16x8. I only pulled up the other site to get offset and backspace.
