bolt pattern conversion
All 6 lugs are 6x5.5
why not swap in chevy or yota axles in the rear?
IIRC Taco axles use a 6x5.5 lug pattern
And the semi float 14bolts use a 6x5.5 pattern
well for one i already put a locker in the back and i regeared it.. and i dont want to have to spend the money do do that again.
and i want to stay close to the stock width of what im at now...
the best solution to this problem would seem to be a D30 then. bolt pattern would match. width would match.
idk how big your going on the tires but more than 35s would be getting dangerous even if its only a 2wd with that axle.
yea im going to be running 38s...
i need a wider rim anyways... i might just have to live with it
where are you located? if your close enough, i can machine them for you.
