- Aug 19, 2007
- Age
- 37
- Everett, WA
- Automatic
All 6 lugs are 6x5.5
The newer 6 lug f150's are a metric bolt patern![]()
specifically?
why not swap in chevy or yota axles in the rear?
IIRC Taco axles use a 6x5.5 lug pattern
And the semi float 14bolts use a 6x5.5 pattern
the best solution to this problem would seem to be a D30 then. bolt pattern would match. width would match.
idk how big your going on the tires but more than 35s would be getting dangerous even if its only a 2wd with that axle.
where are you located? if your close enough, i can machine them for you.
