Just Plain Stupied
Aktually......you drill holes where needed and mount whatever you want to the panels (except an anvil....too heavy)......
then you make a fiberglass resin paste or use good old JB Weld to bond each of the nuts to the back side of the panel....
let it cure for a day or two.....then remove your components.....install the panels and re-attach the components.....
same basic procedure for attaching the panels to the inner walls of the cab...you cuts out 2" X 2" oak squares the correct thickness needed to make the panels sit flush with the door pillars...
drill holes at 12" spacing into the panel.......place a blind nut in the backside of each oak block & cover it with a piece of tape....use flathead machine screws to secure the oak blocks to the panel.....
put a big glob of your favorite adhesive on the backside of each wooden block & place the panel in the cab using good old duct tape to hold it in place til the adhesive cures.....
since I've got three separate panels----- a lower....middle.....& ceiling panel...I'll install the lower one first.....then the middle.....
the ceiling panel will require a little bit different procedure....I'll just space out the drilled holes in the panel........glue the wooden blocks to the ceiling of the cab matching the holes in the panel & let em cure(without any hole/blind nut in the blocks)......then I'll use wood screws to secure the ceiling panel to the cab roof (if any of the screws go all the way through the roof---I'll get on top of the cab & grind em down so they won't be noticeable.....
JUST KIDDING!!!!!!!!!!!!!!!!!!!!!!!WAAAAAAAAAAAAAAAAAAAAAAAHAHA)
Then I'll pull it all OUT and cover it it with really expensive grey imitation leather upholstery.....then I'lll put the 15 speaker covers in place....:icon_surprised: (also kidding!)(about 15 speakers).....
sir yessir. but what about one of them new fangled space age aluminum anvils?
N.C. about Al anvils.
What about this????
id crap on that 2.9 for all the trouble it caused.
atleast you now will experiance the feeling of a V8 ranger/36/ranger/36
naw i went and confuzed meself
That the same thing as an copper magnet? :icon_twisted: Or a left-handed metric screwdriver? :icon_thumby: Or maybe even an AC battery? :icon_rofl:
What about this????
I found the 2.9.....
annnnnnnnnnnd what about this.......the 3 panels clamped together.....
Isn't that weird car-brush shaped pillar going to make it tough to see out that there windshield?
not really grasshopper......you see......the older truks had 2 piece windshields with a metal flange holding the 2 pieces together in the middle.....
So....I'm used to seeing something in the middle of the windshield......(real or otherwise.....but that's another story)
Plus.....when the cigar smoke & mud get too thick on the inside glass....I can splash some mountain dew from my fancy elevating hot/cold cup-holder on the glass & BRUSH the slop off......git it! WAAAAAAAAAAAHAAAAAAAA
id crap on that 2.9 for all the trouble it caused.........atleast you now will experiance the feeling of a V8 ranger/36/ranger/36..........naw i went and confuzed meself
just wait'll i saw off the top of the top of the intake & leave the 3 stacks sticking up & adapt a Harley carb to each stack!!!!
You'll be begging for that motor when you hear it run.....Waaaaaaaaaaaa
Dont waste Mountain Dew!!!!!!!
A view obsructor is a wife that keeps pointing which direction to go.
Don't forget that great device also keeps you awake and agitated on long road trips...you will NEVER miss an exit again... Not even the ones heading away from where you want to go.
I will not touch those comments with a 10' pole.........until I change my password...safety first...Waaaaaaaaaahahhahahahaa
Now where did i put my Ranger-D0 list???????????
across from teh Ranger Dont list??
ahhhhhhh.......grasshopper......you missed it !
Let me re-phrase it........Where did I put my Honey-.....
Naaaaaaaaa....my turn to do what I want......
Where did I put my Ranger-Do list?????
Get It???????!!!!!!
Allow me to be the VA drugs translator. He's saying the hell with what honey wants, he's doing what the Ranger needs.
Did I get it right?
Event Coverage
TRS Merch
