33 inch tires
4byRANGER
when i put my nitto grapplers that are 33's on my 95 ranger 4x4 with a 5.5 bracket drop lift they rubbed on my sway bar and on the ttb trac bar behind it.. i still havent figured out the solution tho
:icon_bounceblue:
wheels with more backspacing,but go too far and it will rub the fenderwell instead.
Sounds like you need LESS backspacing (so the wheels stick out a bit more)
3.75" backspace on a 8" wide rim is generally the best combo on these trucks with tires around 12.50" wide.
oops thats what i meant,you won't rub the fender with more backspacing.:icon_twisted:
:icon_bounceblue:
Remove the sway bar, you will get much better flex offroad. Its not to bad on the road without one. Thats what i did.
