Just Plain Stupied
10-fo...................maybe ............................... i'll git her done................... by post #1500...........................................LOL
Technically it's going to be done by post #1322 on page 89... :icon_bounceblue:
thanks.....i needed that little smart-mouth remark..........Waaaaaaaaaaahahahahaa
i am (seriously) gonna try & get the cap pieces lined up/engine radiatored/sending units installed on sbc & re-wired to dash-guages.....test run down the drive-way a few times......seriously fellas........really....i'm not snickering either.
Originally Posted by mn_smokeater
:icon_bounceblue:
Originally Posted by doorgunner
Remember..........go BACK to page 89 & to post #1322 in the future to view pics.......
that's where any photos will be posted of the swap.....
and THANKS FOR THE ENCOURAGEMENT.....
maybe this won't take 6 months...Waaaaaaaaaaaaaahahahahahahahahaha...
maybe this won't take 6 months.....Waaaaaaaaaaaaaaaaaaaaaa
Did I say the above??????????????????
It's Official!!!!!!!!!!!!!!!!!!!!
I got everything together annnnnnnnnnnd it started running hot!
I instantly removed the thermostat to cure the problem..wrong!
I flushed out the coolant system...clean as a whistle....still runs hot!
My blue flush-fit flex fan ain't pullinnnnnin enough air, even with the HD radiator!
(I thought i had all this ironed out already.....wrong!)
Sooooo.....tomorrow i notch out the firewall 10" X 10" X 2" deep.....no problem.....1 hour
Then...I unbolts the xmsn crossmember.....WAIT!....I never got around to installing it!.....the temporary crossmember is not attached to the frame rails yet & is just waiting to be slut back 3 more inches...Waaaaaaaaaaaaaaa....no problem......1 minute!
Thennn....undo the m.m. mounts.....I jak up the V-8 a lilltle....slide it back 3 ........add an adapter plate to the drivers side motor mount like I did the other m.m.
Weld a rear brace to the underside of each adapter-plate...then bolt the braces to the frame after the engine is slut(or is that slid?) back Thu-reeee inches....
Saw 3 incheaches....?????....off each exhaust....re-re-re-attach the cats....
Install the push-pull lectric fans thats been hangin on the wall 9 months....
Crank it up.....Drive to Sonic b4 thay close at midnighrt......not a prob......1 to 10 hours
Well....thats the plan.....
[/COLOR]
He's crazy
I knew he was crazy
This prove.....ss.... ... ..
Wait a minute....(i'm answeing my own post again)
He's crazy
I knew he was crazy
i wonder what blackwidow is up to....
Sonic should sponsor your truck, they're certainly getting enough advertising from you.
I've made two trips to sonic since you started mentioning them and the nearest one is an hour away.
:icon_surprised:
waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahahahahahahhahaha
thanks.....I needed that!
gotta go
:icon_surprised:
Update: driveshaft is getting dropped/exhaust pipes are getting separated........gotta go
:icon_surprised: :icon_surprised: :icon_surprised:
you wanna run that one by me again?? :icon_confused: :icon_confused:
He's beating around the bush knowing the cup holders still need to be done.:icon_rofl::icon_surprised:
:icon_surprised: :icon_surprised: :icon_surprised: you wanna run that one by me again?? :icon_confused: :icon_confused:
O.K......here goes.......
:icon_surprised:
Ahhhh.....you figured out my secret plan!
thats just it too:icon_rofl:
Gee thanks dangerranger.....now everybody knows!!!!
You make taking this thing apart and putting it back together again look as easy as building legos. If I could just get the red bricks to be that shiny...
