Finally getting to some much needed front end work. Lots of nice surprises including the weather.
need to get a MAPP gas torch today to help with stuck radius arm bolts. The lower radius arm stud inside the drivers side beam snapped off and now rotates with the lower bolt.
Im gonna try the sawzall approach to get it off, and luckily I have a spare set of beams I can use that already have duff pivot bushings installed.
I will then be doing all new moog ball joints, wheel & spindle bearings and seals, c clip elim, 5-760x ujoints, and an aussie locker install which has been sitting in the garage for close to a year now.
and finally finish extending the radius arms and building the brackets to go with them. This is alot of work, but will save me alot of $ when Im done.
