Just Plain Stupied
what was i going to say now.... something about easy acess to teh dizzy??
That engine going into the truck looks like trying to fit a 10 pound turd into a 5 pound bag!!!
But the engine is far from a turd.
*****2022 EDIT...SINCE PHOTOBUCKET DELETED ALL MY PICS I AM REPOSTING MORE PICS******
Sub Thread...2.9L to SBC Engine Swap continued.....
Since the hybrid shaft isn't a tight fit where the two pieces slide together to get a tap-in fit.....then twist the Ranger shaft section to line up the fixed u-joint eyes with those on the sbc shaft.....
Then I'll set the drive shaft on v-blocks and use a dial indicator to keep the shaft true/straight as I tack-weld the 2 pieces together ........then test fit the hybrid on the truck.....then set it back on the v-blocks & slowly weld it solid....
Innnnnnnnstalled!!!!!!!!!!
I sawed off most of the OEM chevy xmsn shift-arm and welded a universal shift arm to the part of the oem arm that slides onto the xmsn shift shaft...
then I floor-mounted the B&M Unimatic shifter/put it in the Park position/ran the cable to the xmsn shift bracket & bolted it on/adjusted the linkage to engage all gears on the auto/xmsn....
Wednesday......I'm staying away from the wiring today.....so here's whats happening to the headers.....I mocked up the 90 degree bend & welded it into place....now to the parts store for the drivers side bend......there's a good view of the passengers side motor mount adapter plate....
It looks like the starter is in the way, but it's only the camera angle----the down-tube easily bolts in place with 1" clearance from the starter.....
It's a different story on the drivers side header...the header tube overlaps the frame bracket by 1/2" .....the down-tube won't fit unless I modify the the connector pipe that's bolted to the block-hugger header (I could have avoided the prob. by using another type header....but that would have made it too easy...LOL!)
I cut notches in 2 different places....tapped the gaps closed with the ball peen...test-fitted the hybrid...then welded everything up.....
It fits!!!!!!!!!!........
boy your just plugging away at that hell you may get that done before i even get my rad from the napa an installed.
Sub Thread...2.9L to SBC Engine Swap (the 2.9L electronics were failing one at a time...after spending $200 on replacemnt parts and still having problems I decided to install the SBC)
O.K.......3"s btwn the dist. and the firewall.....that's gooooood.....the engine can go back 3 more inches...(when I lower the engine on the motor mounts....I oughta get an inch clearance between the dist. & the firewall)
looking good. come monday im working on mine finaaly, check out the stupied thread in the swap forums to check mahh chack list.
Filled in. while your fireing up the SBC il be sitting at work wondering "is it running?"
SBC SWAP HERE
ooooooooooohhhhhhhhhhhh Fire!!!! i like fire!!! fire!!!
standing ovation ,THATS SOOOO COOL CHEVY OR NOT at that point ,it dont frickn matter. very nice dg you are the man.
SBC SWAP GOES HERE...................
DG is the man! oh just remember unlike a truck you cant fix a camera or computer with a gentle tap from a hammer, not that id know that from experience you know just saying.
