- Aug 18, 2009
- Age
- 37
to start this off my explorer will only drive about 3 mph at about 3500 rpm...i've been told tranny issues i believe its rear end issues it i have a 94 ford explorer xlt with the ford 8.8 with 3.73 ratio and limited slip.... driveshaft would spin when in gear but not move truck...in neutral the driveshaft wouldnt spin (with tires on teh ground) jacked up the whole rear end u can spin one tire by hand and the other doesnt spin...spin the pinion yoke/driveshaft it will spin one tire im ost please help me...and here is my rear end findings
well i pulled it all apart today removed everything but the pinion, and attached to the side gears are like 6 plates per side...i wanna say those are the clutch plates (if i remember correctly but not sure) for the LS...and once again if i remember right 3 of the 6 per side should have 2 tabs on it which slide into slots on the carrier.... well i only have one per side and they are closest to the side gear (on each side) i also recovered what seems like the remains of the other tabs in the bottom of the diff...and i see what looks like where the tabs were supposed to be?...i'll post pics in a while to show exactly what im talking about could this be my problem...and i also decided to spin the pinion yoke b4 i removed the axles and it still turned one axle shaft but not the other (this is with it out from the truck and sitting on jack stands) im just lost lol so if u can help me out it'd be super appreciated thanks and i'll get on those pics since they can explain better than i know how lol thanks again
