Today I pulled the bed the truck to access the connector for the in tank fuel pump.
I pulled the 4wire connector. I assume the wire colors mean the following:
Black wire = ground.
Red w/Black stripe wire = power to the pump.
Yellow w/white stripe wire and solid Orange wire are for the gas gauge.
On the wire side of the connector I put a voltmeter across the red w/black stripe wire and the chassis. Key on, Nothing, to voltage at all.
I was pretty happy at this point thinking that neither pump was getting power and the inertia switch consistently has 12v for a moment then drops to 7v.
I was thinking that maybe the computer had gone bad and was causing all of this.
That was until I tried to spin each fuel pump independently.
I made a long jumper wire for power that had a 30 amp fuse in it so that I would not blow up anything in case I touched the wrong thing.
Front Pump:
I got the electrical connector for the front pump from a junkyard to allow me to easily put power it.
I hooked my long jumper directly to the positive battery post then to the red w/black stripe wire.
I touched the black wire to the chassis and Nothing, the front pump will not spin with separate power to it.
Rear Pump:
On the tank side of the connector I ran short jumper between the black wire's connector and the chassis to ground that pump.
Then I used my jumper with the fuse to run power to the red w/black stripe connector. Nothing, the in tank pump will not spin with separate power to it.
I tried to spin each pump in this manner to totally remove any other component in the electrical path.
I really though each pump would spin with separate power to it.
I am really stumped now.
What am I missing?
