Finally Done With My Jump Seat Subs! hope you like!
is it easy to take off the back panel? did you just mount your amp them cut a whole and put it back?
did you use self taping screws to bolt the amp to the back wall
ya it is REALLY easy! 3 screws holding the top mid section on just under the window and maybe 3 more holding on the carpet section. once i undid them i just pulled out the carpet section. i mounted the amp then cut out whole to fit and put it back. yes
yes i did.
so did your screws go throught the back wall to the other side thanks for your help in advance
yes they do. it was the fastest way for me to get it done now. i hope to redo it with a set nuts and bolts. once i get the chance i plan on welding :icon_welder:...(or having some weld because i dont know how..lol :icon_twisted:) a set of nuts to the inside so that i can just mount it up right to them not have to worry about these things sticking out the back even though no one can see them...
if i did it the only thing i would have to worry about would be rain coming through the back, although it doesnt rain much here i dont expect to live here forever but i like your setup good work!
thanks bud! :icon_cheers:
