- Jul 22, 2009
a 6.2 eewwwwww, you have to put those tired old things in 4 low,hube unlocked to brake burn,put in a 302!
3000 mile round trips?
No offense but i wouldnt trust anything "home built" to make that kind of a trip.
later,
Dustin
Hi, Im just wondered what anybody might think about a GM detroit diesel swap in a second gen ranger (89-92). Here Is what I plan on doing, IF I do the swap. Fully boxed frame, ford 9 inch or a dana 60 rear, dana 44 or dana 60 front axle, maybe a TH400 auto but would like a manual, and custom crossmembers. I think the 6.2 would be a good swap because it, uses fairly common trannys, seems to be reliable, and it seems to a bit lighter than other diesels.
Just wondered if any body thought it might be a good swap.
P.S. I know the 6.2 is a gm engine, I do like ford, just thought it might be a decent swap
Actually, to the 6.2's credit, they are better then a 302.
I am not a fan of the 302, they are sooo easy to replacewith a 351.
You only get 15 from a 2.9? Somethin is wrong.
Hell i get 16 from my 5.4L Expedition with 3.73 gears.
7400 is all a Dually diesel long bed weighs?
My buddies 2000 F150 4x4 ext cab with a 5.4L weighs like 5500.
later,
Dustin
those are acceptable reasons for a v8 guy with a big sas 4x4.
just do it. get it done
and get a turbo.![]()
All this talk about swapping a GM 6.2 lit a fire under my butt about my own diesel swap... I plan on using the VM Motori 2.8L CRD (from the 2005-07 Jeep Liberty), if you are looking to do this and are willing to spend some extra cash to save a little weight (I won't be SAS, or over 5000lbs) this motor is the ticket I think... 160hp/295lb-ft... I used car-part.com and found 3 within 100 miles for ~$3k... If what I think is true, you'll be able to bolt this up to a NSG370 6-speed manual+NP231 and have a really solid powertrain that should easily net 25mpg (or more)... I still have more research about transmission and t-case options (I"m not 100% sure about the 2.8L+NSG370 compatibility)....
+1
thats .....
you ......
you have to be kidding me.
unreal....
i am fuggin speachless![]()
if you do it ill be watchin that one! take lotsa pics
It might happen sooner than expected, just found one for $1250!
You're still on crack. No full size truck maintains 22mpg while towing a 5th wheel trailer. You're math is MASSIVELY flawed. These trucks barely make 20mpg on the highway with no load (some of them don't).
