Hi Guys
My big concern is the Transfer case bearings getting lubricated properly.
I have heard that on some transfer cases the oil is moved around properly because of the input side of the tcase.
IF the case is in neutral and the input is not turning but the output is turning because of the driveshaft, then the rear bearings are spinning but not getting lubed properly.
Therefore the rear bearings in the tcase may be at risk of burning up.
I have heard that it might be best to have the Transmission in neutral but the tcase in 4hi, that way the gears moving in the tcase spash enough oil around to keep everything lubed.
I was hoping someone here might have a definitive answer about this.
Thanks
Bill
I just bought this 89 4x4 5speed last night, (Now we have 3 Rangers
) I used a flatbed uhaul to tow it home just about 80 miles.
But I almost had to use a dolly because the place I first tried was out of flatbeds and it took him a long time calling around to other uhauls to find a flatbed. That's why I am asking, just in case I might get stuck in the future with a dolly instead of a flatbed.
Thanks again,
Bill
