measure the compressed height of the coils as it sits and post up.about 14.5 for the 4" lift and 16.5 for the 6" lift.anything shorter won't work.
10" wide wheels will effectively put more leverage on the beam and sag it .5-1" as well.
if they are the 2.5-3.5" duff dual shocks then they won't keep you from reaching ride height.but you should have longer shocks for a 4-6" lift if you want any droop, if they aren't for the duff 5.5" lift.
if the shocks aren't limiting it and the coils are tall enough you do indeed have beam and or balljoint/bearing/eccentric issues.
