- Aug 7, 2007
- Opelousas La.
Well i am planning on rebuilding and have been researching the option of a 331 stroker. Originally I planned to do a 347 but I've been told the short pistons cause issues and make the 347 a weak engine for high horsepower and reliability. . and I'm takin the time to figure out the best, most reliable and durable engine,
If i put the AFR heads, roller everything, and 331 stroker kit, Is nitrous an option for the track? can i have the intake ported, ar do I have to buy a nitrous ported intake? and when running nitrous, will the 4 barrel holley 600 found from factory work as a suitable carb or Is a carb am important choice when trying to run nitrous?
Ok, you say you want power AND reliability? So that there rules out Nitrous (in my opinion) Don't settle for a flat tappet block as a foundation. There are thousands of roller 302 blocks out there to choose from. If you haven't found one, you haven't looked. Don't know where you're at, but I've got two extras. My 331 has Canfield heads (same as the AFR165's), a Ford Racing Z303 cam, 1.7 rockers and has PLENTY of power. I built it 5 years ago. Still going strong. Been in two vehicles now, my 89 Ranger for a year or more and now in my 77 Comet. Ditch the stock 4 bbl Holley, I'll bet it's the 4180 hybrid Ford used (it's a Holley/Autolite combination, not suitable for performance)
