- Mar 12, 2009
- Age
- 55
- Lavergne, TN
- Tire Size
- 37x12.50-17
Your on crack if you want to get rid of it for that reason...you know that right? There are so many of those heads on ebay and in junkyards. You could have that thing apart and replaced overnight after you get the new/used head. On top of that a cracked head is primetime for more mods. If you dont want it though. give me a ring.
1st things 1st...Hey chico, I wasn't trying to thread jack man, I wish you luck with whatever you get!! I had just found out about my cracked head about 5 hrs b4 I saw your post & it was fresh on my mind.
froggy...Seems like "crack" is literally my problem. I'm just frustrated. It is quite a task to replace, way more than an overnight deal. I can't get enough out of it the way it is to even consider selling it now, so it will sit until I can afford to fix it I guess....& yes, more mods will probably go along with it.
Evan...It is both a money issue at the moment & the ridiculous amount of work involved, fortunately my dad runs his own shop, so labor will not be a factor. If I'm not mistaking, the engine needs to come out to do it.
