I recently had a misfire on #2 also then it was #4 I found a crack on the bottom of my coil pack, replaced that and still no change changed the plugs with no help there also the wires were just replaced about a month back and I decided the check the wires again and sure enough they were defective replaced them under store warranty and it fixed the problem, so I would check over ur wires again just a thought.
I keep getting number 2 cylinder misfire code. I changed wires and plugs still no change only seems to come on when idling if that helps!
FYI, cylinder #2 is looking at the engine from the FRONT of the vehicle on the LEFT side, not sitting in the vehicle.
Hey look! What I just said in a picture!![]()
that is why design engineers refer to driver/passenger not left/right.
