fastpakr
⭐Supporting Member
- Aug 6, 2007
- Roanoke, VA
- Tire Size
- 285/75-16
I'm trying to sketch out a basic install for my Ranger. I've fiddled with amps before, but never really put together a complete system and just want a second opinion. Trying to create a simple, affordable system that covers all the bases. To do so, I want to use a four channel amp mounted in the center of the back wall, and two sealed 8" boxes behind each seat. The wiring sketch is attached. I might not end up using this amp, but I want something similar to power everything. 100x4 at 4 ohms, and 150x4 at 2 ohms. Each of the rear channels would tie into an 8" SVC 4 ohm sub. Each front channel would get front and rear components for one side. If I did this, I'd get 75 watts to each component set at 2 ohms. Will this damage a speaker set that's listed as 4 ohms? Do all the numbers sound right?
