- Mar 25, 2009
- Farmland IN
I have an 87 4x4 2.9,so far since I got it last month I have replaced the following:gas tank,fuel filter,gas cap,O2 sensor,CTS,hoses,radiator,front brakes,air filter,exhaust,plugs and today the dist.cap and rotor and plug wires. I set the TPS and the lowest I could get is was .96V. I kept having a problem with the idle bouncing around and running rich at idle when hot. I have it running MUCH better than when I started BUT.....today I changed the dist. cap,rotor and wires. After that I found out my Uncles timing light didn't work. So I drove it to Autozone to see if they "loaned" timing lights but they didn't so I drove back to the shop and decided to clean the AIC valve to see if it would help the idle since I'd have to drive it 30 miles to use my Dads timing light. I took it off and it's the original (147,100 mi.) and cleaned it with what throttle body cleaner I had left(not much) and sprayed out the ports with carb cleaner. I started it and it runs horrible! Like a V-4! I tried moving the dist again with no change,I took the valve back off and put a little permatex on the gasket and blew it out with the air hose and still no change. Did I hurt it with the compressed air? The only other thing I did after driving it to Autozone was wire tied the wires down and routed them carefully. The engine still dies if I unplug the AIC with it running but it runs like it has a huge vacume leak and I checked all the hoses and lines. I double checked all the plug wires and they are all on. Can a bad or failed AIC valve cause it to run this bad? Thanks for the help.
