it will bang out around 5500 on my 93, if its an auto it wont let it go past 5500 (mine wouldnt at least). my a4ld had a tranny limiter, first floored would go to 52, 2nd would go to 75, 3rd was the limiter tapping OD on the shift bezel (speedo only reads 85), was told it was 109. the engine will bang out and will never shift to 4th gear unless you back off the throttle and cruise, you then lose some speed. this is stock trim wfo for 23 seconds in my modded form, basically no a/c (cut it out) HAI and high flow cat/super44. my trk was 4wd, dont know if that makes any dif.
