- Aug 6, 2007
- Age
- 34
- '93
I still wanna see the steering D44's front and rear!! 4 wheel steer would be awesome! You know you want to do it!!
I had thought about dumping a smallblock in my ranger and using the 2.9 out of it, but I think the 2.3 is a perfect balance of lightweight and power in these things.Loanranger, looks like another awesome build. I gotta be honest, I wish the mazda had the 3.0 in it. But, I good running fi2.3 with a M50d and like you said a couple of transfers behind, this thing is definately gonna be wicked! Can't wait to see what axles your gonna use.
Oh I know I want to, it's just whether it's feasable at this time. If I came across a ford D44 for the rear, there would be no question, but trying to make the best of the turd of a CAD axle is going to be a pain. I'm sure I'd never have a problem with it, even if I left the CAD in, and just perma locked it. Or cable lock it, so I would essentially have a cable locker if I welded the spiders. It would be the same idea as unlocking a hub, but without having to get out to do so.I still wanna see the steering D44's front and rear!! 4 wheel steer would be awesome! You know you want to do it!!![]()
Not a biggy, The first case will be a range box only, so really all I need is a hi-low shift. Either by linkage or just a 90* shifter, this one is fairly simple too. The third, and most serious problem is in bearing oiling. I won't have a drain, but I will have a fill hole at approximately halfway. The shift forks will still be submerged, but instead of the mainshaft (outputs) being submerged, the input will be. Whether the gears will sling enough oil to keep everything lubricated?
I got a trailer lined up for tomorrow, to bring the ramdatsun down here. SO hopefully soon I'll be able to continue in on this thing.
Just a question, if you go with a front axle in the rear what do you plan on doing about the gears? Since they would be running on the cost side of the gears, hence making the gears weaker.
all im saying is that even tho its stronger than the samurai gears its still going to be turning 37's or 38's a you said erlyer. and if i remember correctly the bigest tire size the d44 is rated at safely is around a 35 and thats going forward.
but if i might make a sugestion why not use the center section of a rear and cut the axle tubes to the lengths you want and use the outers and shafts off a front axle?
not trying to say your wrong or anything just my .02
What is with the oil bottle? Does it go through that much oil or something? I was thinking maybe it was fuel and you have a gravity system, but it would go through that qrt. or fuel like NOTHING.
