pics of done product
skyy_4life
Boosted (Not Stock)
Brooklyn Ohio
this is pictures of my fresh new turbo. entire build from start on a 1994 2,3 ranger. video will be up soon.
dad cutting out core support for intercooler
shitting myself hoping for no scratches.
done....
thanks for looking guys. i will have video up soon. turbo worked out great and at 7 psi boost. that truck is amazing. pics of new engine build up asap also. i baught a TC motor and got forged pistons and rods to build a 30psi turbo ranger. ill keep u guys updated.
holy intake tubing batman!
i have always wondered if these were exhaust turbos or what?
Nice looking man :) By the way, I would try to figure a way to get your fan shroud back on to avoid overheating problems with that nice new setup...
what is that breather on your intake tube after the maf, before the turbo?
yea on the natural air intake side theres a pipe running to maf and a cold air cone. i wont need that shroud soon because i have a electric fan just never got around to putting it on. the plugs are Bosch platinum II, packs are Accell Performance, and wires are Accell 8MM. wires are just little bigger than stock wires.
looks nice except i would plug the hole where the tiny filter is that is a big MAF leak and it will run like shat
This is what ive been waiting for for so long! it looks beautiful! How long did it take you to put that in?
yea tunning is next, my friend jess from turbo ranger forums is doing my comp. and yes that little filter was just kinda a plug for now i will run its to valve cover asap, planned on it but always forget. it took about 2 weeks to finish everything and thats only working on days i have off and after work when im not extremely tired. if any of you guys live in or around cleveland, the april meet in on the 11'th if u wanna see this truck in action, go to regional forums to get details.
...and yes that little filter was just kinda a plug for now i will run its to valve cover asap, planned on it but always forget...
I wouldn't do that. That will only make the inside of your intake and turbo look like a well used chimney. Just plug the hole in the intake and put the little filter on the breather on the valve cover. If it doesn't fit right on top, put in on the end of hose normally used to attach to the intake.
yea thats wut i was thinking. my friend has his cold air intake ran to his throttle body and his valve cover with a little filter on it. but yea thanks for the info.
What kind of turbo are you running?
