- Mar 22, 2008
- DeKalb
- My credo
- Life is short- Play naked!
If anyone wasn't aware, I just found out a couple days ago...
As of July 2006, Illinois went to a flat weight plating fee for vehicles (trucks).
So now, "B" class plates are 8000lb GVWR or less, and 8001-12000lb GVWR are class "D". Probably most 3/4 and 1 tons fall in to this catagory.
For those that don't know, a "B" plate fee is $78/yr, and the "D" plate is $158.00 a year. The "D" classification also requires that every 6 months, you have to take the vehicle to a certified mechanic, and have it inspected- mine cost $20 each time. So basically it's $200 a year for plating my F250 SD.
How I found this out:
My truck (8800lb GVWR) was originally plated as "B" in 2001 when I bought it new, and the GVWR classification break was 8801 or less. I actually reclassed my plates to "D" on my own in 2006, not knowing the new "flate rate" system was in place. I did it for the lift on my truck, and it stopped me being hassled by the cops all to often.
Anyway, since i'm only averaging around 300 miles of use every 6 months with my truck- I wanted to save a little cash and reclass back to the lower rating, hence not having to go through inspection every 6 months ($40), and also $80 less for plates a year.
So they told me at the DMV that I couldn't because of the GVWR, and the application would be rejected downstate. I have to stay with the "D" class plates.
So to wrap this up, even though the state has or did not notifiy owners of the new law- If you get stopped with a "B" plate on an 8001lb or higher GVWR vehicle, you are potentially subject to a $1500 fine for wrongful classification, and possible 90 days jail time. This is what Springfield told me yesterday afteer about 2hrs on the phone with them... This is of course dependant on if the officer knows the law in regards to this.
Makes me wonder how many are on the road with the wrong class plates these days, just because they are unaware.
Sorry for the long post, it's just a heads up people! Good luck out there.
