- Nov 17, 2007
After three months, I've finally located a nice replacement for my rear-ended 87 BII. A very well maintained 88 BII, with minimal rust, a good body, signs of being well maitained, and everything basically looking good.
Except . . .
It's a cold day (~30°F), and I ran the vehicle in the dealer's lot for about 5 minutes. Then we went for a ~10 minute drive. During this time, the temp gauge climbed fairly high (more than 3/4 of the scale), before dropping back. When we returned to the lot, I noticed that the interior vents were not blowing much heat. Hose going into the heater core was quite hot, return line warm only. Running the engine for another 5-10 minutes gave slightly warmer air, but not what I would expect. (All dash slides seemed to be functional.) While I was looking at something else (engine off now), the dealer opened the rad cap, and there was a spray of hot radiator fluid. The radiator, however, was not full (down 3"?). The upper rad hose was hot, the lower hose, hardly warm.
I realize that if there are cooling issues with these engines the heads crack. I immediately checked the oil, but it had VERY recently been replaced, and was super clean and fresh, with no sign of emulsion. (Dealer claims he has not had time to do anything with this vehicle.) I then removed the oil filler cap, and there was a small amount of off-white colored "grease" in the hollow portion of the cap. I ran a finger down inside the oil filler pipe, and was able to extract more of this off-white "grease" from inside the valve cover. It looked and smelled a lot like automotive hand cleaner.
1. Opinions? (It's a nice BII and I want to buy it.)
2. Is there ever a whitish grease inside the valve covers that is NOT from antifreeze leaking? Is this ever a normal condition?
3. Is there any definitive tests for head cracks that can be easily performed?
4. If the heads had to be replaced, can this be done with the engine in? What is the cost of replacement heads? How involved?
Any experienced input would be appreciated!
CraigK
Except . . .
CraigK
