- Aug 28, 2007
- Durham, NC
There is no option on a 2.3 as to other than stock. No EFI system made for a 2.3 can compete with 350 holley 2bbl. There are much higher flow carb systems than that.
Esslinger had a write up on a NA 2.3 making 200hp with side draught webers.
They wouldn't say how much horse they were making on their drag car but, it used MECHANICAL fuel injection.
They have a chart showing the motor making more hp and tq throughout the RPM range.
That was with a modified iron head.
Again, comparing apples to apples (stock) the 2.3L makes more HP with EFI than with a carb. I'm not talking an option, just comparing different model years when EFI was introduced on the 2.3L.
You could put a 500CFM Holley 2bbl on a 2.3L and it would not make any more power, 2.3L of displacement can only pull so much, and the basic principle of EFI is far superior to the principle (venturi effect) of a carb.
And the latest advancement to fuel systems is direct injection, which operate similar to a diesel's injection system:
http://cars.about.com/od/thingsyouneedtoknow/a/directinjection.htm
