It's a lot easier to explain if I'm explaining it to you while you have a master cylinder disassembled in front of you.
The pedal pushrod (or the pushrod from the booster) pushes against the piston that drives the front brakes.
but the "end" of the cylinder is the back end of the piston that drives the rear brakes.
So this piston is doesn't provide pressure for the front brakes directly, because there is a stiff spring between them.
and the front brakes aren't applied until either there is pressure in the rear circuit, OR the spring on the very front of the piston stack starts to compress and provide resistance.
Basically this allows the REAR brakes to apply first before pressure
is applied to the FRONT brakes changing the
stiffness of these springs would change the point where
the front & rear brakes begin to apply...
And just how much rear brake you get...
The REAR brakes are driven by the piston and a single seal pushing against the closed end of the cylinder.
The FRONT brakes OTOH aren't applied until pressure builds in the front chamber (this is opposed by a softer "Return" spring) and that causes the spring between the pistons to collapase.
The thing is that the FRONT "piston" is formed between the back of the REAR piston and the front of the front piston... In other words until that spring between the pistons is compressed NO pressure is applied to the front brakes.
So by applying a stiffer "return" spring up front you an get more front brake but changing the middle spring affects both.
Make that "middle spring" softer you get more front less rear.
Make it stiffer you get more front less rear.
And that is all without changing the bore diameter of the cylinder....
And Ranger Master cylinders came in three bore diameters, 15/16"('87-88) 1" ('89-94) and 1-1/16" ('95-?)
I'm running a '94 1" bore cylinder on an '90 booster with 1997 two-piston calipers. All this in a 1987 truck
The brakes are by my consideration "right" but I'm going to have to start all over again when I swap in an explorer disc axle.
AD
